My FP5 will not turn on after I replaced the screen. It did briefly after I replaced the screen, then died due to low battery, but after using several different chargers, it did not turn on. I have checked the charging unit and taken it out and put it back in, but still nothing… I had occasional issues with charging before, but nothing like this.
I would suggest to you that you dismantle your phone and dubble check whilst assembling that you have connected all the connectors. It seems impossible but you never know if a connector of the charging post came loose. For the manual of dismantle and assembling check Ifixit
