Hey, after failing to find anything online (sorry if I missed something), I was wondering if someone knows a solution for my issue:
Is there any option to deny access to menu settings when the screen is locked?
Currently, I am still able to access all the menu settings (quick settings) when the screen is locked. But I don’t want anyone to be able to deactivate my mobile data/wifi. Is it possible to adjust single menu seetings that it would need my fingerprint/pin if activated/deactivated (e.g. GPS has such a feature)?
I tried also a couple of apps, however, unfortunately, I couldn’t find anything suitable for my issue.
I hope, I was able to describe my challenge good enough
By the way, I’m aware of the customizability of the quick seetings, however, that doesn’t really help me in my case as far as I can see it.
Thanks anyway for any hint or recommendation!
