I installed last year /e/OS on my FP4 (I’ve had unlocked it) and everything went well.
Today I wanted to install LOS 20 instead /e/OS and everything went very bad !!!
I do not have any more OS on the phone … I’ve got only “Recovery screen” and screens of LOS for ADB and Fastboot, and my phone is locked again.
I did read in diagonale as we say in french and I didn’t see similar pb since My phone is lock and I can’t find out to unlock it. I checked my cable, version of ADB , version also of LineageOS, etc.
what point do you think would help me in this post?
That’s perfect! Then select “Reboot to bootloader” (twice “vol down” and then “power button”) and wait for “bootloader” to start.
As soon as the “bootloader” (the “other” “fastboot” mentioned in the topic above) is started, then please reissue your fastboot command.
You’ll only be able to unlock your device in the “first fastboot mode screen”!
So if you get <waiting for any device" then your phone is not correctly recognized and you can just try
Oh, then I’m very sorry, but it doesn’t look good…
You’re now probably here:
What you might try now:
check
fastboot flashing get_unlock_ability
I’m afraid it will show “0” (which means OEM unlock is disabled and that’s why unlock is not allowed…)
You can only enable “OEM unlock” if you can boot your system.
So did you already check all ways to boot your LineageOS installation?
I assume you already tried a “factory reset” and test if LineageOS boots then?
If you do not manage to enable “OEM unlock” then you’ll probably have to contact FP for a repair at Cordon repair service…
(bootloader) get_unlock_ability: 0
OKAY [ 0.000s]
Finished. Total time: 0.000s
I just undestand it’s a bad news, right ?!
I didn’t installed LineageOS. I had /e/OS and I begun the procedure to install LOS ans when I restart my phone I’ve had the pb !!!
