Black Friday (until Sunday) at iodé!
The “small” FP4 now costs 543 € instead of 659 €, for example. It is even cheaper than Fairphone (579 €) itself. The “big” FP4 and the FP3+ are also in the Black Friday offer.
Update iodéOS 3.3 (now open source!):
- 24/11/2022 (build 20221121):
- The wide-angle lens now operates with the preinstalled camera app (OpenCamera)
- Improvements in the blocker user interface (iodé app)
- LineageOS synced with September security patch included
- All apps updated
Ive had iodeos installed since 3.1, all has been pretty good but the iodeos networking app would reboot my phone if i launched it since the 3.3 update. But phone worked fine if i didnt launch it. until…after ota update from iodeos 3.3 to 3.4 my fp4 rebooted fine one time. I then opened the iodeos networking app to see if new update fixed the aforementioned issue. The phone froze and rebooted. It then stuck on the opening.iodeos splash screen. Then I tried to reboot and it stuck on iodeos splash screen and sent me to recovery. in Recovery i tried.to reboot and it says cant load android system data may be corrupt etc. Etc. what to do? What fix would work so i dont lose all my data? Or can i downgrade back to 3.3 without losing my data via sideload update? There may be an offending app, but I cant boot to safemode even if i wait for the iodeos animation and then hold the vol. Down button still it will not load safemode. It just restarts phone to the bootloader.
have you checked the Iode Community especially reg. the app issue (btw which one is the networking app?). Have you tried multiple times 7-10 to reboot from recovery, this might force to change the slot. not sure if its possible to start in safe mode when you are in the bootloop state.
Downgrade will mostlikely always cause a data loss.
Thanks, I went through about a dozen successive boot , iode splash , recovery, boot , iode splash , recovery cycles. The slot never changed and unfortunately neither did that pattern. I am still unable to get into my os to find the offending app. I can’t believe there isn’t a safemode built into iodeos.
The iode networking app I am referring to is the one to the left of the iode news app. The iode networking app is a white circle that says io on it. It acts as an adblocker/hosts file firewall.
@fizzstep Android has a safe mode, the moment you see the boot splash (not the vendor logo), hold volume down, after a moment you should feel it vibrate, then let go. The system should then boot and say “safe mode” in the bottom left. It doesn’t always help, but give it a try to get your data off, then maybe do a fresh install. And make backups in the future!
Hi thanks,
If I hold vol down and wait for iodeos logo there never is a vibrate, so I have no cue to let go. I just keep holding and it reboots to recovery. The phone vibrates when it gets the initial fairphone splash screen so we know the vibrate should be working.
I tried holding vol up too no luck. I tried holding vol up and vol down simultaneously …still no luck why isn’t there a Linux entry point if these hardware methods do not work?
Have you modified the system in any way, like installing Magisk?
What happens if you turn the phone off and connect it to your PC via USB while keeping Volume Down pressed? It should boot into fastbokt mode so you can change the active slot with fastboot --set-active=[a|b]
. The current slot is written on top of the screeb.
You need to wait for the iodéOS logo to appear before you hold Vol. Down.
(Doesn’t vibrate in CalyxOS btw, still boots me into Safe Mode just fine if I keep holding it)
iodéOS 4.0 (LOS 20 based) has released yesterday as beta for first device batches
FP4
Pixel 4/5
OnePlus 9/9pro
Sony XZ2
So, after DivestOS (LOS) and calyxOS (AOSP) it is the third A13 ROM for FP4
…And it seems that it is running very smooth on FP4
At least there hasn’t been any negative feedback from the iodé community so far. But on the contrary
Edit 20230110
Yesterday, they released the second beta with January security patches
But remember what @mikeNG mentioned here:
https://forum.fairphone.com/t/fp4-and-lineageos/77347/602
As for re-locking the bootloader still applies to iodéOS as well
Official iodéOS 4 (Android 13) is out!
XDA:
• Upgrade to iodéOS 4.0 based on Android 13 / LineageOS 20
• Blocker:
○ Improved blocking settings. You can now choose ‘Standard’ blocking (ads, trackers, malwares, etc) or ‘Reinforced’ blocking (same objective but more extensive), and then select additional categories.
○ The ‘Porn’ category has been extended to a wider ‘Sensitive content’ one, that also includes fake news, gambling, drugs, piracy, torrent…, with mainly child protection in mind.
○ The ‘Extreme’ category has been removed, as it is now part of the reinforced blocking.
○ Improved blocking lists. We merge several acknowledged and up-to-date sources, and have diversified our sources to produce more complete lists. The standard list has however been reduced a bit, to avoid as much as possible interference with apps expected behavior.
• Added a new network location provider: Local NLP Backend. It is an improved version of the DéjàVu NLP backend which was already available in iodéOS. Like DéjàVu, it builds a local database connecting localizations learned from other NLP backends and apps using GPS, and mobile antennas/Wifi; but also has an active mode (not preselected) that can trigger GPS requests. To configure it: Settings → System → microG → Location modules
• LineageOS synchronized with January security patch included
• All apps updated
• New devices support: Pixel 3, 6, 6a
I recently received my new FP4 and I’m still considering which custom ROM to install. iodé is currently my favored solution, but not 100% sure yet. What I’d like to do: just install iodéOS , try it out, install some apps that are important for me and check whether they run smoothly. If not, then I’d consider trying another custom ROM as well.
In that context, my question is: after flashing iodéOS, how easy is it to set back the FP4 to its original state? Or at least flash a different custom ROM? Or is there any" permanent" change introduced to the FP4 when installing iodé?
Of course, I’m aware that I need to the backup all the data and that I risk bricking the phone if something goes wrong during the process. My question is more about: is there some principle limitation to be expected, even if all the steps are executed correctly?
Not for the LineageOS bases ROMs, like iodéOS is, as long as you take care with locking the bootloader. Especially when returning back to stock.
As far as I know, only Ubuntu Touch may mess up with some sensors when reverting to stock, but this is reversable, too. You can read about it in the corresponding thread.
New and general features
4 Webview choices
as i know iode is the first security and privacy based custom ROM where I can choose between all of the the security based WV versions!!!
Hy all
I would like to try iode and running my FP4 currently with the latest version of calyxos. Can I just install the iode os or do I have to return to stock rom first? Any other things to consider? I just really dont want to brick my phone. Thank you all for advice!
You can install it directly that way:
or with my instaructions, which are already actual:
Two important things
be sure to remove calyx avb_custom_key before flashing iodèOS
fastboot erase avb_custom_key
before re-locking bootloader, be sure that:
check if bootloader unlock ability is possible =>fastboot flashing get_unlock_ability
→ (bootloader) get_unlock_ability: 1
==> if you get 1 then you can re-lock
==> if you get 0 do not lock bootloader
a good starting point for questions in case of problems is the iodé matrix room:
Thank you very much AlphaElwedritsch! I was able to install it today Everything went smooth - also locking the bootlader at the end with no issues at all.
