FP4 - very privacy-friendly custom ROM iodéOS
I now believe that no one has any perspective at all. In which situations and with which constellations it works or does not work.
There are so many different options:
  1. Which OS do you come from, which version?
  2. Where do you want to go, with which version?
I’m now at a point where I can’t say anything more and, above all, can’t recommend anything anymore.
Just my advice, just like @anon73661646 already said: Until there is no and above all tested solution, I would leave the bootloader unlocked.
Lots of discussion, lots of confusion. I myself have no more perspective.
here in this Thread
and here and here …
I tried 220407, 220405, slot a and b. It doesn’t work for me.
I thought for a short time to test the /e/OS version, but life is short and I don’t want to waist my time with test- and debugging. I bought to use, not hack the phone. I’ll finish my configuration and if the rest work’s, I’ll keep the bootloader unlocked. All my phones before had an unlocked bootloader.
Thanks a lot for your help my green friend :wink:
I finished my configuration. Perfekt, 114 apps an only one is not working! :+1:
German DKB banking app told me I should download the latest version for Playstore. But it is the latest version.
I love the rom and the hardware. For somebody who want’s to keep away from app tracking is iodèOS definitely the best choice. But I would recommend to order the phone direct from iode.tech to avoid installation trouble, like I had. Sadly my order was placed before I saw that. Anyway, for me it look`s very good, except for the loader. If I win in lottery I’ll buy another one.
Have fun guy’s and a nice weekend :v::slightly_smiling_face:
Yes, for me it was also 220407 - coming from FPOS (updated).
Today I also tried: flashing FPOS again (There was an issue with flashing the frp partition, but in the end I could boot FPOS) - just to flash 220405 again (as far as I understood this was exactely the setting that worked for you @anon9231953 wasn’t it?).
Still… same old problem. I will surrender for now as well and will just use 220407 with an unlocked bootloader…
@anon9231953 I appreciate your efforts very much. I can totally understand that at some point your support comes to an end. For the next months, I will stay with an open bootloader. And for those who might be interested I will give an overview what I tried else:
I tried changing back to the original FPOS with the instructions from the support page. I came from a very new but updated FP4 before installing iode for the first time. For installing FPOS I unlocked critical now aswell. Everything worked well but this time the get_unlock_ability turned to 0 and in the OS the OEM unlock button turned grey.
After that I tried calyx (because why not…). I installed it successfully. But the OEM unlock button stayed grey. Interestingly after flashing and before the first boot into the system I tried get_unlock_ability in fastboot and it returned 1. After the booting and going back into fastboot it was 0 again.
So in the end I installed iode again because of the developing state of calyx and stay with everything unlocked. The OS works very well and except the wide angle camera and the missing option to show the network usage in the status bar I don’t have any complaint about it.
I use iodéOS on a FP3 and have the option to enable Network traffic monitor under Settings → System → Status bar
It’s not available (yet) in 3.0 for FP4.
And as I remember not in 2.4, too.
If I right, it depends on LOS codebase, if it is available or not.
iodé is deliberately very close to LOS. When developing and customizing the ROM, they limit themselves to their own apps and cleaning up Google. Therefore, such features either come into the ROM via the LOS code base or not.
Maybe it’s not available for a device with the notch in the top middle (like FP4 as this is where it would be displayed)? Just guessing…
It is available in Calyx, so it’s probably already in the LOS sources for Android 12.
They moved it right next to the clock, looks awful in my opinion:
I’ve never used it, so :man_shrugging:
I have iodéOS 2.4.
Strange, I’ve had this feature with every LOS build I can remember. I thought this was a standard AOSP feature…
hmh yes, that could be a reason why they left out this function…
Your right man.
The problem is definetily the notch
On the right side is no space left for that
On the left side it will take the whole space for notifications
If it would be available, I would never use it. So I don’t miss it.
And yes, it looks realy awful…
On my wifes OPO 6T I use LOS4microG. LOS19 (A12) available since two days now.
6T has also a notch, and traffic monitor does not exist, too.
It is the same minimalistic 19.1 LOS as for iodé. Many missing things actually, but what I don’t find disturbing, because everything important is there
New Beta released today (20220509)
  • Visible changes are new screen off fingerprint switch and location indicator muted for NLP providers.
I updated to the new Beta today (was on the latest 2.4 before) and had bluetooth crashing everytime I tried to enable it.
I managed to make the bluetooth work by:
  • Turning on “Disable Bluetooth Hardware Offload”
  • Clearing the cache and data of the Bluetooth system app
  • Unpairing and pairing all of my bluetooth devices.
:partying_face:
Only if you update
Not on clean installs
New 3.0 (A12) Beta released today:
Nice! :slightly_smiling_face:
Are there any notable advantages or disadvantages compared to A11?
Neither one nor the other. Purely a matter of taste
Maybe the one advantage that I think that the development only continues at 3.0 and stops at 2.4 and thus also the Gogol security patches
Hey @rar0: Thanks for the patching and rooting guide! Just one question, regarding the patching steps:
Could you replace steps 6 and 7 with the following?
  1. Extract boot image (replace [slot] with current slot):
adb shell dd if=/dev/block/bootdevice/by-name/boot_[slot] of=/sdcard/boot.img
  1. Reboot
New beta out in the wild:
3-20220524-FP4
changelog
embedded apps have been updated
lineage sources synced
