FP4 runs hot in the front, near the USB-C Port, restarts - Not Plugged in
For some months I have the following problem:
Whenever I use an app (Youtube, Reddit, games, mail, etc.) the phone runs hot on the front side (kind of next to the usb-c port). The phone then freezes and restarts. It doesn’t matter if it is plugged in or not, it happens either way. Cooling the area (I took an ice cube in a cloth) delays the restart.
I checked the backside, it doesn’t run hot in these situation.
The USB-C Port ist 1 year old, same as the battery and the display.
I rechecked the hardware so everything is plugged in the right way or if I find any dirt or burn marks, but it was all in order.
I also tried my old battery if the problem lays there, but it was the same problem again.
Has anyone experienced the same issue?
Welcome to the community forum :slight_smile:
More to the left-hand side or to the right?
How long does it take (from when you start a video or game) for the bottom of the screen to feel hot?
This certainly shouldn’t happen just with mail or web browsing, though I guess it would be less surprising after an hour or two of video.
I would avoid that unless you can be sure no humidity is getting in contact with the phone (plastic bag?)
Anyway, this is not normal. I think you should contact support.
Its in the middle, where the circle-buttom is.
Sometimes it Takes 3 minuten (sitting in the toilet browsing Reddit) sometimes 30 minutes Up to an hours when I watch a long video.
Thank you for the Info with a plastic bag. I did the cloth 2 times to see if it was a heat related problem and restart. (And ist looks like ist.)
I will check out the support, thank you.
