Vous aussi vous avez l’icône “Wallet” toujours allumée ? Ce n’était pas le cas avant la mise à jour Android 15 sur mon téléphone…
D’autre part, avez-vous contacté le support “officiel” Fairphone pour signaler ce bug (car c’en est bien un) ? Je n’ai pas bien compris si c’était nécessaire ou pas…
So I have the same screen flashing problem here, my phone is usable though but a bit laggy and has some stuttering. I also get the quickstep message not working.
Though I’m not with Orange and never was, I’m with Free. And I don’t have a sim card, it’s e-sim.
An e-SIM is also a SIM card. And it seems its sufficient to have roamed in the Orange network, somewhere. Do you have the Orange Apps on your phone?
Orange installs “bloatware” on your phone and this was identified by others as root cause.
I have the same issue here after doing the Android 15 update. Clearing the cache of the Quickstep App doesn’t work. I used a Orange SIM in the past, but since a few months I have been using a Free SIM only.
This issue was reported from 2 users within the beta phase. I’ve also provided an error log within the issue, but unfortunately, it was not fixed before the release.
To use apps, I figured out that Gemini still worked. So eg you can also give it the command to open the playstore as an alternative to the above described way.
I did the update in early afternoon, just before leaving home. Quickstep now keeps shutting down according to a pop-up. the home screen keeps flickering and I can’t select anything. Can’t access the apps so in particular I can’t install/uninstall anything. My phone is unusable.
Can’t you test your updates before pushing them to users? What do I do now? do I really need to figure out how to go through factory reset or whatever do clean up your mess? Even if I do, the phone will ask for installing the new version of the OS, do I have to refuse them and potentially have security isues?
What if this happens to someone who is moving around and needs his phone for train tickets or whatnot? What were you thinking?
The general rule with FP is do not update the phone when you really need it. Plan the updates to times when you can dedicate some time to problem solving. And, of course, read the forum before installing.
Uh-oh. Luckily I came here to check before installing, I was afraid something similar might happen.
I sure hope Fairphone will get quickly a grip on this problem (chances are good given it apparently affects all Fairphone models). Till then, no update for me, more so since one of my SIMs is Orange… Having a working phone is vital, if the phone reboots I’ll be unreachable till I notice it.
(Before someone tries to tell me “but there are so many people who have no problem” - Sorry, I’m not a gambler… )
If you already know the update will cause problems as you use Orange, of course it would / will not make sense to do the update. This is not gambling. If you already know that this will happen to a lot (or maybe all) Orange-Users I would rather call running the update despite better knowledge stupid.
Still there are many non-Orange Users that use the updated FP4 without problems. And if one is not directly part of the affected group of users having problems, I do not understand why the update should not be performed, just because there a a number of reports about problems with the update. This is where usually the topic “quiet majority not having problems” kicks in.
What I do not understand is, that this problem seemed to have occurred in the beta testing already and still it was not fixed before the roll-out. They should at least have mentioned a problem for former or actual Orange-Users.
