FP4 not starting, support team is not responding
My Fairphone is defective. It won’t turn on, even with the charger. It doesn’t respond at all. I submitted a support request on July 8, but I haven’t received any response yet. When trying to reach someone through the live chat, I found that only an AI responds there. I don’t know what to do anymore. Can someone help me?
Welcome!
Is it a new FP and are you never been able to start it?
Or what do you think is changed before the problem?
Have you tried to remove the battery?
Thank You!
My phone is about 3 years old. Fortunately I got a 5 year warranty so I „just“ need to get in contact with the support.
Before the phone „died“ it was stuck while booting (I always turn off my phone before going to bed and restart in the Morning). To get out I removed the battery and re-inserted it. After two or three times trying to reboot the phone it stayed off.
I did not change anything.
Perhaps your battery is to low on energy.
If you are lucky then a Fairphone Angel is living in your neighbourhood and has a Fairphone 4.
You should be able to get it to boot:
  • if possible use a power socket with switch for precise control
  • connect the phone to charger for 2 seconds
  • you need to disconnect before anything shows on the sreen.
You may have a problem with the power button.
If nothing happens and you can’t even charge the phone then there remain two possibilities that I can see
Either the battery is dead (if you have a spare or if possible follow Lidwien’s advice to find out)
Or it’s something worse. Again, a FP angel might be able to help. To contact support try the chat between 10 - 12 weekdays.
Could the problem be the USB module? Do you remember if the last charge did the job?
I don’t know how, but if the battery is low and the problem stay in the USB port, you could try to charge the battery in another way.
Edit: something like this: External universal chargers for Fairphone batteries
Thank You for response. Unfortunately nothing helped yet. Before the phone “died” the battery was at 65%. It is not possible to start the phone even with plugged power supply. There’s nothing on the screen or any vibration at all when I push the power button.
I will try to contact a Fairphone angel but I’d prefer support through the FP support team since I still have warranty.
The live chat only offers me chat with AI bot, I tried it every weekday (10-12).
That’s very disappointing.
Lie to the chat bot that you don’t have a ticket number yet and you will be able to speak to a human, during those 2 hours on weekdays
Did you try this? Or have any luck any other way? I’m having the exact same problem with my FP4. I know it’s charged but I can’t turn it on. So am very interested to hear if you’ve had any luck.
