FP4 minimum screen brightness too high
Hi together,
my wife and I are proud owners of the new FP4 and enjoy it hardly.
However, the minimum screen brightness at night is a bit too high.
We would appreciate it to make the screen even darker.
I saw the topic regarding the the minimum screen brightness of the FP3 and the problems which occurred with the automatic brightness adjustment.
Does the FP4 suffers under the same problem, which is why the minimum was set so high?
Or is it possible that you simply adjust the minimum via update?
Thank you very much
Rick
A post was merged into an existing topic: Auto brightness doesn’t go to 0% in dark environments (minimum is 30%)
