Hi, my #fp4 doesn’t go lower than 30% when unlocking my phone at night. I was expecting that the phone would learn this preference, but after a week it still doesn’t go to 0% at night. The screen of the #fp4 can’t really go very low anyway, with auto brightness at a minimum of 30% it’s not great for my eyes
I’ll contact support to ask if this can be improved. For those who want lower brightness than the phone default, Android 12 includes an option to go down a notch further (not sure if it’s Pixel exclusive though). So maybe in the future that will come in handy.
my wife and I are proud owners of the new FP4 and enjoy it hardly.
However, the minimum screen brightness at night is a bit too high.
We would appreciate it to make the screen even darker.
I saw the topic regarding the the minimum screen brightness of the FP3 and the problems which occurred with the automatic brightness adjustment.
Does the FP4 suffers under the same problem, which is why the minimum was set so high?
Or is it possible that you simply adjust the minimum via update?
The FP4 on the left is running Calyx A12, the FP4 on the right FPOS A11, both with Night Light disabled and at their lowest possible brightness setting.
Even if it might not be completely apparent, there is a significant difference in minimum brightness, so there is the possibility for improvement.
Not really. The minimum brightness has been deemed to high for some people. There was an attempt to lower it and at the same time adjust the automatic brightness. This failed in that the auto brightness made the screen effectively turn off with the lower settings.
The only resolution was to undo the update so it is back to how it was.
It’s a personal issue, unless soem phones are different. We have two FP3s and an FP4 in the family and everyone thinks the lowest brightness is fine.
So no it’s not high, it’s the usual default. Whether it is personal or your phones is debatable.
Apparently there are apps that can override the Android 11 settings but it may require rooting the device.
Maybe try to turn nightlight on, I have it always on on the FP3, because for me its also to bright (was the same already on the FP2). Its not perfect, but I would say with nightlight on its better.
Hmm usual default for the FP4. However, It’d be nice if one could change the default. I don’t think that our both devices are somehow brighter than the default ones.
I’m currently not planning to root the devices, as some apps require it not to be so.
Thanks for the suggestion. I already have the nightlight on. I can confirm that this feels better but is still too bright in our eyes.
While playing with the brightness slider, I observed, that the first half centimeter of the slider doesn’t change the brightness at all. Maybe someone can confirm this behavior.
I can confirm that behaviour, but it’s the same on all 3 Android devices I have access to at the moment.
My guess is that’s there to account for thumb thickness
It’s in Digital Wellbeing, which should be part of a default Android install. It creates a black and white filter as well. But the brightness is only slightly minimized by it IMHO.
I had the same issue using the app I mentioned as occured with the previous FP3 updatre where the screen went dark in the day.
It seems the app disbled ‘autobrightness’ sort of make sense, but then for some reason, maybe it was on and then put in my pocket, the screen was dark ‘black’ and even in the sun would not adapt.
I had to go somewhere vcery dark to be able to see anything when I swiped down from the notification bar.
Ok manged to get brightenss and uninstalled the app.
I am another new owner of a for and I can confirm that the problem is still there.
The automatic brightness control goes only down to somehow 30%. Using manual control I can go much lower. So this looks like a bug in the automatic and there will be no app as a solution
