Hi there,
after my sd-card slot physically broke on my… 2 year old FP2, I bought a FP3. Then I tried to install some things like Blokada, fDroid etc via the sd-card I put into the FP3, but to my surprise, the sdcard is not shown in the explorer in win 10. Here’s what I did:
I unlocked the bootloader but did nothing else, Especially, I did not install twrp, another OS or something like that, I did not even install any other app at all.
I set “MTP” for file transfer to no result other than Win10 detecting the phone as a device but not displaying it in the WinExplorer.
I set “PTP” as a work-around following the instructions here:
https://support.fairphone.com/hc/en-us/articles/360032831351-Connect-your-Fairphone-3-to-a-computer-Windows-Mac-and-Linux- Result is, the phone is now shown in the Explorer, but internal storage only, not the sdcard. -
I took another sdcard, this time empty. No other result.
I formated the empty sdcard through FP3. No other result.
I de-installed my ADB-driver on Win10 and re-installed it. No other result.
I locked the OEM-Bootloader again. No other result.
Then I did something I wanted to avoid badly: I logged into my WLAN before installing Blokada, updated the phone and tried 1-7 again. No other result.
I set the device back, deleting everything. Starting from the scratch in case I missed something. I formated the sccard again, just in case, you never know until you look. No other result.
Anything I might try (again)?
Just in case: I use the original USB-C cable which came with the FP.
Night.
PS: Edits only grammar and spelling.
