I have an issue with my loudspeaker when on a call.
When using in a call on loudspeaker the volume is super loud. Changing the sound options (anywhere) does lower it to a reasonable level. I also noticed that raising the volume does not go much louder than the “minimum” volume.
When holding the phone on ear it is perfectly fine and adjusts the volume in reasonable levels.
I have had this issue since the purchase of my phone. I have done multiple factory resets since then due to other issues. Have had the mother board change due to a charging issue. etc.
Is there a known fix for this issue?
I perused the forum for info on this, but could only found closed threads which did not have any definitive fix.
