Unfortunately, my new FP3 keeps restarting… I know of the problem with the FP1, but have not installed Facebook nor Twitter… Anybody have a solution?
I tried removing battery, SIM and SD card.
Hi JBL,
I moved your question to its own topic so hopefully it will get more attention.
Not sure if I can help as I don’t have a FP3 myself, but can you describe a little more when the FP3 restarts? Like all of a sudden during usage? Or immediately after boot?
IT kept restarting immediately after boot.
I replaced the SD card and problem seems solved… 64gb replaced by 32 GB card
Hmm thats interesting, could you try using another 64gb SD card? Perhaps the one you were using had a problem or was shorting something.
