For a few weeks now, my FP3 is charing unreliably.
When I put the charger it says “slow charging”, and in fact the battery level continues to lower.
If I reboot the phone while charging, it works.
It is kind of annoying to have to reboot my phone each time I want to charge it…
You may like to try running in safe mode to disable apps to ensure that isn’t an issue.
You may also have a problematic cable or charger, can you try other options? I’ve had similar problems but with a new Fairphone cable it is all but sorted.
Hi Thomas
Yours is similar none the less, to this problem, solved with a new cable.
I take it you’ve made the routine checks, cleaning the port and so on (be careful not to damage the port when cleaning - and don’t forget the cable connector too).
Any exposure to damp conditions?
Could you specify which OS and version you’re using. As Urs says, this could be software related too.
Thanks!
