…and it survived!!
With almost no damage!
There is seriously no scratch on it, except the camera doesn’t work anymore, but I can live with that
I’m so proud, good karma pays guys
…and it survived!!
Can’t you just buy a new camera module?
Sure, I guess I will try to fix it sooner or later…
Which camera there are two?
and it may just be a loose connection. You may want to take the phone apart a bit to check.
See
and
Since the fairphone 3 and 3+ are the samze size, you can choose yourself! The one from the 3+ is better, but also more expensive
Was your FP3 in a case or not? If yes, which case?
And welcome to our community!
@mariasu If the simple, first version FP3 cameras are enough for you and yours is really beyond repair, have a look here:
