I try to explain the prob, that is not very clear,
when my phone power off because of battery down, I attach the charger cable and aspect that my FP3 show the images that appears when I attach it with battery cable.
But nothing appens…
I need to detach it
open the rear protection
remove and reinstall battery
then, when I attach the cable again… it start to show the screen images and start to charge.
Does this mean that you let the battery run all dry until the percentage was 0 %? That’s something not recommended to do because it can reduce the total battery life expectancy. And it might result in such “behaviour” as the one you are describing.
You can check the voltage on the battery via dialling *#*#66#*#*
then Service tests > Test Single > Battery status check.
The percentage may not be calibrated accurately but have a look at the voltage reading at say 30% 20% 10% etc to help understand.
Also the application that reads the battery charge is calibrated to the battery, and there is a learned charging routine for each battery: ~ swapping batteries will add issues.
So maybe removing the battery resets the not so clever AI that is trying to help
when I dial the string ##66## the screen goes white fo 3 second and the reappear the data that were displayed befon.
I mean: no menu.
because this appen?
what can I do?
There is another way of getting the menu, if you have Developer Options enabled
On the Fairphone 3 there are Service tests available via Settings - System - Advanced - Developer options (how to enable them in Android is all over the internet) - Service Menu - Service tests.
However if you have entered the correct dialling CODE then there is some concern.
It’s not exact science. Try to not let it run below 20%, but the phone/battery will not spontaneously combust if you do occasionally.
0% is really bad, as you found out already, don’t let it run to 0%.
