warenbe
September 13, 2023, 6:12pm
1
Hi
my FP3 died. suddenly. i took it from my pocket, black screen, no power at all
i though battery was discharged, but plugin in the cable does nothing…
i took my multimeter, and measured 3.8 v at the battery (check the left and right pins, where it’s written “+” and “-”
so, i think battery is still charged.
can it be the bottom module ? if yes, the phone would work but not charged right ?
if i plug in the USB battery, i see 0.11 A from the charger. not more.
what should i check ?
yvmuell
September 13, 2023, 6:43pm
2
MMGA
September 15, 2023, 3:44pm
3
This has happened to several of us
Less than 3 years ago I bought a Fairphone 3 because of the company’s claims about longevity and environmental footprint. My phone stopped working this July after it overheated for no apparent reason. Fairphone repair centre sent me a quote for 337,61 euros for the repair and said that the phone stopped working because of an electronic fault on the motherboard.
I was very disappointed with the quote given as I may as well buy a new phone for that amount of money, and mainly because I bought the…
The motherboard of my fairphone 3+ is dead in a bit more then 3 years. I have contact FP support and what I have is a repair of almost 300euros.
The idea of the company is really good but the product I had never works properly. Is a pity but i will never recommend anyone to buy fairphone from now on.
this is just to express myself
I bet is the motherboard. If it is not under guarantee fairphone will not replace it or repair it even tough is clear that a faulty batch has been sold to several of us
MMGA
September 15, 2023, 4:30pm
4
