I got my FP3 this week, bought a cable that charges it (it’s a IF certified cable) and started using it.
So far I can tell that the battery lasts a full day of heavy usage, and a couple of days of normal use.
In the setting menu I see that battery is 3060 mAh, but Ampere (the app I use the o check the effectiveness of the charging cables) tells me it’s 2000 mAh.
If the battery was 2000 mAh it wouldn’t last that much, not with this screen, so I’m not questioning the real capacity of the battery.
Has anyone found a difference in the battery capacity between the Android setting menu and other apps?
Well, your battery hasn’t been charged to 100% yet, so maybe the estimate isn’t definite yet? Have you measured the capacity before with a 100% charge?
I doubt it’s measured. Going by the Ampere page on XDA, it relies on Power profiles for Android. Power profiles for in Android, in turn, needs a configuration file (platform/frameworks/base/core/res/res/xml/power_profile.xml) that specifies a lot of power values, including battery.capacity.
probably the system image on the FP3 is shipped with faulty (FP1 specific / someone forgot to edit/update) profile entries. It wouldn’t affect the low level drivers or how long the phone really lasts, but apps are going to report the wrong value.
