đŸ‡«đŸ‡· 🇬🇧 FP2 stuck in fastboot mode
Bonjour, mon FP2 ne s’éteint plus!!! il est bloquĂ© en mode fastboot je pense, (clignote bleu lentement) aprĂšs une tentative d’installer lineage Os en suivant les tutos puis avec TRWP. Je peux le redĂ©marrer en recovery TRWP mais impossible de le redemarrer normalement,ni l’é
teindre! ni avec les boutons, ni avec reboot de TWRP. Je viens juste de depenser 160 € pour changer la carte mĂšre
 Je suis dĂ©sespĂ©rĂ©e. quelqu’un peut m’aider? pleaaaase
Hi and welcome to the comunity,
my French is not good, so I will write in English and translate with deepl:
Which Lineage Version did you install?
The current Version is 18.1 and this is no longer compatible with TWRP.
So I would flash the Lineage Recovery and then use this to flash Lineage
Quelle version de Lineage avez-vous installĂ©e ? La version actuelle est la 18.1 et elle n’est plus compatible avec TWRP. Donc, je voudrais flasher le Lineage Recovery et ensuite utiliser ceci pour flasher Lineage.
https://wiki.lineageos.org/devices/FP2/install
thank you for your quick reply, I fee less lonely.
I tried with TWRP because I didn’t managed in the first place with lineage recovery.
I have just typed the cmd :fastboot flash recovery /home/administrateur/Téléchargements/lineage-18.1-20211203-recovery-FP2.img and the result is
Sending ‘recovery’ (14182 KB) OKAY [ 0.450s]
Writing ‘recovery’ OKAY [ 0.324s]
Finished. Total time: 0.778s
now I’m not quite sure what to do next
Now you should be able to boot into this recovery using Vol-up+power. From there you can use adb sideload or a SD card to move forward with Lineage installation as described in the official instructions linked above.
yes I have managed to get into the lineage recovery.
A went to the “apply from ADB” stage, and typed
adb sideload lineage-18.1-20211203-nightly-FP2-signed.zip
it returned:
adb: failed to stat file lineage-18.1-20211203-nightly-FP2-signed.zip: No such file or directory
when I put adb devices it says:adb devices
List of devices attached
f8b3f6a1 unauthorized
but I don’t know how to change that
It seems adb did not find the zip (to say it in quite non technical way) try to copy the entire path of the zip folder (e.g. adb sideload C:/user/downloads/lineage.zip)
I also tried:
adb reboot bootloader
administrateur@pc-celine-2020:~$ adb devices
the process stopped at 47% with last line:
serving: ‘/home/administrateur/TĂ©lĂ©chargements/lineage-18.1-20211203-nightly-FP2-signed.zip’
(~47%) adb: failed to read command: Success
I think my battery is running low at this stage, I suppose that doesn’t help the process
Just retry when the battery is charged again
A BIG THANK YOU anyway for your help, I’m getting nearer :grinning:
GREAT!!! I didn’t have to do anything else.
According to the installation guide, also it wasn’t clear for me,when it says: “(~47%) adb: failed to read command: Success” It means it worked. So all is well now. Again, Thank you very much!!
