FP2: SIM slot 1 better than 2?
I use two SIM cards in my FP2, the same as before in the FP1 for many years. The primary one in slot 1, the second card only if I would have signal problems or similar (but both using the O2 network).
Recently I replaced the second card with a new one, but again O2 (https://forum.fairphone.com/t/o2-testkarte-fp4-5g/ (my first with a flat rate for 30 days ;-))).
But as so often the signal performance of this “second card in the second slot” is very, very poor, with luck “Edge”…
Now I swapped the cards - and “suddenly” I have LTE speed.
Long story short: are there (such) differences between the two slots or does my FP2 simply have a defective SIM2 slot?
Thanks!
webaschtl
On the Fairphone 2, you can only set one SIM card slot to 4G or 3G, the other one will then be restricted to 2G. It’s a hardware limitation, nothing to do with reception or any technical difference in the SIM slots.
Which is not to say that any particular SIM slot would be unable to develop a malfunction. It’s still possible that one slot works better than the other.
https://support.fairphone.com/hc/en-us/articles/360018557777
Even though, interestingly, it is more clearly spelled out in a different support article … https://support.fairphone.com/hc/en-us/articles/360018532198
"- IMPORTANT -
If you set one of the SIM cards as 3G or 4G, you MUST set the other SIM as 2G."
2G in this century? – Okay, I respect it :wink:
THANKS!
Edit:
from https://support.fairphone.com/hc/en-us/articles/360018532198:
→ do I have to really change the default setting “LTE (preferred”) for my formerly primary card, now in slot 2, to “2G”? – Or “Wurscht”, as you would say in German? :wink:
You can use only 1 SIM at a time for mobile data and you should set this one to 4G and the other one not used for mobile data to 2G
Okay, than NOT the default setting (of /e/ OS).
Thanks!
