FP2 Screen can't be reactivated during/after calls - See first post for Workarounds
Edit: apologies for repeating part of @paulakreuzer’s message, I was called away when drafting the response and only now noticed you already got an answer.
Just a quick note to avoid any misunderstandings: Fairphone staff do occasionally show up on the forums, but at the end of the day it is a community forum for discussion between users. Further to this, none of the moderators are Fairphone employees either.
Other than that, I hope the workarounds in this topic can make life a bit easier whilst Fairphone come up with a more durable solution (last I heard is that the product team is investigating). Other than the ones mentioned in the first post, I recall that plugging a headset in and out of the phone will also turn on the screen.
Increasing the touch and hold delay may help there:
Depends on what the quality problem is exactly. If it’s because the camera doesn’t focus at short distances, you should be able to get a replacement camera under warranty. If it is something else, the 1.3.6 update saw ‘initial’ improvements to image processing, so this is at least something they’re working on.
Note that if you’ve had the phone for less than 14 days, then it’s easy to return the phone for a full refund - though you will need to file a support request stating that you intend to the return the phone in the two week cooling-off period - you do not have to specify a reason. Fairphone support staff will then guide you through the process, though they may take a while to get back to you. I’m not sure what Fairphone’s policy is on returns after the cooling off period. I’m mentioning this in case you’re about to run out of that two-week window.
Good to hear you managed to open the phone. If anyone else needs hints on how to open the phone, there’s a collection of tips in this topic:
So that’s € 500 + well spend :slight_smile:
I would love to read a blog post about this. Even if they are not able to find a quick solution, communication about how they are investigating issues would be a cool read. Other companies tend to deny and secretly fix stuff through updates and smaller callbacks, often just to protect their suppliers or their “image”. More transparency in this department would make FP stand out and enhance trust in them … and their suppliers.
Same problem here - just wanted to add to the crowd… Also filed a report a few weeks ago, but haven’t heard back from the team yet.
Incidentally, has anyone of you heard anything back from official Fairphone channels on that topic yet?
Same Problem here. As soon as i start a call the screen turns black and i can not activate it anymore. Before the last Update i could activate the screen by pressing the on/off Button during calls. Pressing the on /off Button twice did end the Call. My solution for now is to plugin a headphone to the Headphone jack. If i do so, the phone reactivates the screen for a while. A simple Hack but not realy a solution. I am not sure but my problems with this started after the last Update.
An other solution i just tried right now. When the call does start and the screen turns black (off). Rub with a finger at the area where the proximity-sensor is and the screen of my FP2 turns on again and i can use the whole thing like it should be.
Currently Fairphone have a support article on this issue available here.
I’ve included the link in the first post as well, so it’s easier to find.
same issue here - but it is definitely NOT a proximity sensor issue: because the screen goes black with the phone near nothing. I place a call, and when I turn the phone vertical, screen goes black, far from anything including my ear. And the screen does not come back on and there is no way to end the call except by removing the battery.
That may still be a sensor issue: If the sensor sends wrong data (for example because of dust or a malfunction) it would tell the system that is near something (leading to turning off the display) even if it isn’t.
That’s the best example of a malfunctioning proximity sensor.
Check the first post. There are many workarounds that help you avoid this.
This is making me crazy. It happens daily to me (even though I clean the sensor) and I have to open the phone and take out the battery in case I catch a voice mail. Can someone please tell me what to do about it? I am not interested in some “workaround” but a solution to the problem. I am a busy man and this is also why I can’t bother to read the 295 replies to this post above. I believe that Fairphone must provide a proper solution for this problem - a better sensor or whatever, I don’t know, but I cannot use my phone this way. Also (as far as I am told) it is very bad for the phone to remove the battery while the phone is running.
Please read the first post for a summary of what this community knows. There is also a better workaround than removing the battery. Reading the post and activating the workaround is probably quicker than removing the cover…
If you really don’t want to use a workaround, just a little hint: you don’t have to take out your battery to restart the phone. Simply holding the power button for 15 seconds does the same thing, without having to remove the cover :wink:
Nope. It obviously doesn’t work. Nothing happens when I press the power button. Then the other part ends the call, the power button works again.
It takes about 15 seconds to remove the battery - reading 295 replies here will take hours.
That’s why the title of the topic says “See first post for workarounds”.
Also it’s not always about speed but also safety and efficiency.
Removing the battery is done quickly, but opening the phone when angry can cause the cover to break and rebooting drains the battery.
Press it for 15 seconds (maybe a bit longer if you count fast :wink: ). Just pressing the power button obviously does nothing, except for those who followed the workaround in the first post.
I mean, the title says to read the first post and that’s what I suggested too, no? That’s quite different than reading hundreds of posts. But if that too much to ask, here are some excerpts from the first post:
And here (you’ll need to actually take a look at the first post for the image link):
Obviously these don’t fix the underlying issue, but different ideas still float around in the thread.
By the way, I don’t find it a very good idea to complain about lost time on a community-based forum where most of the people trying to help you are doing it on their own time.
