I recently did a factory reset and also put in a new battery.
During night time, when my phone is charging, it restarts itself. Anyone know a way to fix this?
Also, anyone know why “do not disturb” is automatically turned on when I’m on a call?
Thanks in advance!
Ida
Disable any network connectivity e.g. activate flight-mode and have another try.
Does it also happen when you use the speaker while calling?
Maybe it’s a form of input from your ear or cheek due to a non-functional or badly calibrated proximity sensor not cutting-off the display.
Maybe re-calibrate it with the tool in settings->maintenance->proximity sensor
This could help.
system
Closed
3
