1 This release includes a new system setting for enabling OpenGL ES 3.0 support. On first boot you will receive a notification linking to the setting. You can also find it in Settings → Maintenance → Enhanced 3D graphics support.
Please report any (new) issues through the public bugtracker and upvote existing issues if you are affected. As usual, please specify the steps to reproduce, and provide as many details as possible.
Nah, tried manual. A couple of times, with SD and SIM removed even, just to be sure. Upgrade finished successfully, no errors, nothing - and it just won’t boot. No clue what’s going wrong, but that’s what backups are for. I’ll have my FP2 back the way I like it in a few hours.
Update went smooth, phone started feeling hot immediately afterwards.
Activated OpenGL 3 and deactivated it a few times.
It doesn’t feel hot now, but the phone drains a full battery in about 4 hours.
Any ideas?
This failed with the bundled TWRP version with earlier OS versions, too. I guess when it comes to installing stuff the bundled recovery only does OS updates.
Just install a recent TWRP from twrp.me again and try with that.
Odd, TWRP is giving error message “Invalid zip file format!” on both OTA and manual installation modes. Maybe because I had to manually upgrade TWRP (3.3.1-0) after installing 19.08.1?
I tried that, but twrp.me is giving a error. I can’t reach the website, not on my phone, not on my computer.
Can you try it for me to see what is going on?
Strange I also can’t reach that website.
‘This site can’t be reached’.
“The IP-address of the server of dl.twrp.me can’t be found.
DNS_PROBE_FINISHED_NXDOMAIN”
Update system
Reinstall TWRP:
Connect your Android device to the PC. Type the following into the command window to boot your device into bootloader/fastboot mode:
adb reboot bootloader
If your asks for permission to “Allow USB debugging”, tap OK.
Once your device boots into bootloader mode, type this into the command line.
fastboot flash recovery twrp-3.3.1-0-FP2.img
Hold power to power down, hold power and volume up to boot into recovery
Check TWRP configuration, reinstall OpenGAPPS from memory or SD card
Reinstall Xposed
Activate High accuracy location, agree to Google terms
Reinstall Widevine
Fix app permissions, disable G00gle Play services and G00gle Play Store permissions (except for location) block location for unnecessary apps
