Do you have one that’s no longer working? If so did you try to remove the black sticky rings around the screw hole, on the side of the contacts? Sometimes this helped.
Thank you very much! I dind’t even had to remove the rings, but there was too much glue. I just removed the glue around the rings and now it works again
