Looking for FP" Bottom Module in UK
(Once you have found the product you were looking for, please add [FOUND] in front of the topic title or ask one of the #communitymoderators to do it for you)
Where would it/they need to be shipped (country or city)?
Other, remarks:
NB: If you are interested and want to send a direct message, please check #how-to-dm .
Be aware, that cross-border shipment of batteries outside a phone is virtually impossible for individuals .
Hi Just to let you know there is a post about repairing the module if you can not find a replacement, so what is wrong with the one you have ?
@JohnHughes (thanks again) send me two broken bottom Modules some days ago. This one has a defekt µUSB port.
After disassembling I took a picture with a microscope camera and found some solder cracks. Barely to see without magnification. Two cracks at the shield contacts that I am not too worry about, but also one at contact 5. I am sure that was a slack joint. Some serious force must be acted to the Port.
I will try to resolder the joints and hope the bottom module will be able to do its work…
system
Closed
July 1, 2021, 3:56pm
3
