Am looking for a working FP2 bottom module.
The module would need to be shipped to Italy (Rome)
NB: If you are interested and want to send a direct message, please check how-to-dm .
Be aware, that cross-border shipment of batteries outside a phone is virtually impossible for individuals .
Hi and welcome to the forum.
As the bottom modules for the FP2 are in demand have you thought about a repair, either by a shop or yourself.
The usual issues are failing to charge and the microphone not working.
You can see efforts to do self repairs, which a shop can reference via
@JohnHughes (thanks again) send me two broken bottom Modules some days ago. This one has a defekt µUSB port.
After disassembling I took a picture with a microscope camera and found some solder cracks. Barely to see without magnification. Two cracks at the shield contacts that I am not too worry about, but also one at contact 5. I am sure that was a slack joint. Some serious force must be acted to the Port.
I will try to resolder the joints and hope the bottom module will be able to do its work…
As fairphone angel (in Berlin) I have a lot of support cases with nonfunctional microphones in the bottom modul. A lot of users have minimum the 2nd, often the 3rd bottom module. Mostly easily changed by Fairphone support in warranty.
But there is a lot of waste (I collect old faulty modules and send them back for recycling).
So my questions:
Did anyone successfully repaired the microphone inside the bottom module by soldering a new smd microphone?
What’s the reason for the highly rate of f…
All the best.
Hi and thanks for your reply.
It is indeed that the microphone is not working. I would love to repair it, but am not a technically skilled person. I looked for a fairphone angel here in Rome, but could not find any.
If you have any contact or idea, please let know.
Thanks again,
Katja
