I’m looking for a FP 2 bottom module as mine is broken (primary microphone out of use).
If you have one, I’ll be interested for a shipping to France (I leave near Paris).
Thanks for your help
Pour les français : si vous êtes près de Paris et que vous avez un module inférieur de Fariphone 2, faites-moi signe. Si vous êtes plus loin et que vous pouvez me l’envoyer, n’hésitez pas
Merci !
NB: If you are interested and want to send a direct message, please check #how-to-dm .
Be aware, that cross-border shipment of batteries outside a phone is virtually impossible for individuals .
amoun
April 19, 2022, 9:24am
#2
Hi and welcome to the forum.
As the bottom modules are in short supply you may want to consider a repair via a shop, a friend or DIY
Here are some posts on the subject.
As fairphone angel (in Berlin) I have a lot of support cases with nonfunctional microphones in the bottom modul. A lot of users have minimum the 2nd, often the 3rd bottom module. Mostly easily changed by Fairphone support in warranty.
But there is a lot of waste (I collect old faulty modules and send them back for recycling).
So my questions:
Did anyone successfully repaired the microphone inside the bottom module by soldering a new smd microphone?
What’s the reason for the highly rate of f…
https://forum.fairphone.com/search?q=bottom%20repair
Thanks for answering ! I’m not sure being able to do self repair of the mircophone… but I’ll look at this solutions however.
system
closed
April 26, 2022, 10:53am
#4
