It’s hard to say. I have merged all changes in AOSP code and now have to go through incompatibilities in Mediatek code. Unfortunately I can only see what breaks one project at a time: I fix one project, the next project breaks, I fix that, and so on …
Edit: While I was typing this, I was building … the build succeeded without failure. Exciting. Fair warning though: If something compiles does not mean that it works …
Yes I had this problem too… very annoying. Vidéo works great on my phone but other person gets pixel like images. Sound’s ok though… What’s that about?
Very weirg stuff happened to my phone during ski vacation: suddenly battery lasted longer that usual… I was very surprised that after several hours I was still around 80%.
Then I got a notification that the SD card was damaged… I took it out (managed to save all data on computer because for the computer it was not damaged) and then, without SD card battery life started dropping… after few hours I was at around 30%.
I formated the SD card, put it back still got a message that it’s damaged. Took it out again…
That’s certainly interesting because I can reproduce this at will just by restarting my phone or just starting the updated.
And I get a stacktrace which looks like a bug in the app.
Perhaps a clear of the download manager’s storage will help?
Edit: No.
03-02 14:34:24.580 D/su (27434): 10160 com.fairphone.updater executing 0 /system/bin/sh using binary /system/bin/sh : sh
03-02 14:34:26.023 E/AndroidRuntime(27393): Process: com.fairphone.updater, PID: 27393
03-02 14:34:26.023 E/AndroidRuntime(27393): java.lang.RuntimeException: Unable to start service com.fairphone.updater.UpdaterService@422cef58 with Intent { cmp=com.fairphone.updater/.UpdaterService (has extras) }: java.lang.SecurityException: Invalid value for visibility: 2
03-02 14:34:26.023 E/AndroidRuntime(27393): at com.fairphone.updater.UpdaterService.startDownloadLatest(UpdaterService.java:255)
03-02 14:34:26.023 E/AndroidRuntime(27393): at com.fairphone.updater.UpdaterService.downloadConfigFile(UpdaterService.java:170)
03-02 14:34:26.023 E/AndroidRuntime(27393): at com.fairphone.updater.UpdaterService.onStartCommand(UpdaterService.java:112)
03-02 14:34:26.308 I/DEBUG (27488): [OnPurpose Redunant in preset_info] pid: 27393, tid: -1361051648, name: UNKNOWN >>> com.fairphone.updater <<<
03-02 14:34:28.253 I/WindowState(1751): WIN DEATH: Window{42fa1d88 u0 com.fairphone.updater/com.fairphone.updater.FairphoneUpdater}
Edit 2: According to Stack Overflow, this issue occurs when the app trying to download something tries to hide the download from the user but doesn’t have android.permission.DOWNLOAD_WITHOUT_NOTIFICATION (which holds true for the updater). So I guess the solution would be either to download without hiding the notification (eg. removing this line:
We have a fix lined up for that already. It is going to be in our upcoming releases. However, we did not consider it urgent, because afaik this should only ever happen if Updater is run as user app. This should not happen when Updater is installed as system app, which is the case for all our phones…
Thanks for finding this bug: Apparently we forgot to make Updater a privileged app when migrating (in JB all apps in /system/apps/ used to be privileged by default).
in 4.2.x There was a widget with some basic system settings switch on/off like:
Wlan
Bluetooth
Brightness of Screen
Data Synchronising
GPS
some other system settings you can reach via pull-down like some of the points above plus some more like:
Display timeout
Data Connection
Accu
Audio Profile
now, it seams that the widget is gone (or am I too stupid to find it?) and the pull-down setting menu has changed.
I think it would be a good practice to gather all the setting points in one place (widget OR pulldown), but more important is maybe the question what setting points should be in the menu.
actual collection (pre3) is ok, consists of there items:
I can see whether the widget is still somewhere in the code. I am pretty sure there are similar widget to be found in several app stores.
About the other changes: They are part of the newer version of Android and we do not want to change them. I know that changes are often annoying (especially if features get thrown out) and I also know that not all changes to Android are for the better.
However, we do not want to deviate from Android source (unless necessary to get the phone working) because doing so makes it harder to maintain.
Thus, we won’t re-implement features and focus on the actual bugs we still have.
