I have the problem that my FP 6 automatically turning the ringtone to mute, nearly every day.
I bought it with Google und changed it to /e/OS.
So I miss calls. I cant find a solution which is working, I tried everything.
One thing I found out today: there is a setting to enable mute by power + volume up. It’s in sound and vibration → shortcut to prevent ringing. Since I found that plus reading your post, I realize that may be the cause for unintended muting I also experience sometimes!
I am on Android btw, so not sure if that setting exists for you.
Hi lennert,
thank you a lot, that solved the problem.
