I try to flash a Android 10 with TWRP. but then i got this error in TWRP i try to flash the phone.
But then i try to slet the Data only i i got the error
Is the phone broken/defekt??
How can that be fixed?
Which Android 10? Of the stock ROM? Lineage OS? /e/?
android 10, i have sue that OS to install it many times, but then i got this error in TWRP format,
in photo it says, (Full SELinux support is present)
How about installing without TWRP then?
Fairphone OS gets installed in Fastboot Mode.
/e/ gets installed in Fastboot Mode.
The install guide for LineageOS doesn’t say you should use TWRP, it offers its own recovery for the install.
found a solution.
In TWRP wipe -> Format Data -> yes
it works now.
