I forgot my lockscreen PIN and tried it five times. What can I do?
If possible, answer in german language.
Thanks a lot!
Maren
Ich nehm an du redest ĂĽbers FP2 also hab ich deine Frage nach #fairphone2help verschoben.
Wenn das nicht stimmt kannst du es jederzeit auf #fairphone-help ändern.
i don’t know if paulakreuzer answered you, but just in case, 2 options in my knowledge :
if you try and fail too much time, you should have an option like “pin code forgot”, and it will allow you to use your gmail password to unlock it
go to your computer, go [google play] (https://play.google.com/store) , click on the gear on the top right of the screen, select “android device manager” , you should have a map with an overview of your phone, if the feature is activated by default on your phone ( it’s not the case on all phone), you should be able to click on “lock”, then you will be able to set a new password for your phone, wait 3-5 minutes, then go to your phone and unlock it with the password you set earlier
Thank you very much!
I do not want google to know at all times where I am, so the map does not work and I was not able not find the “lock” option. The german google play looks a little bit different as you described it.
Instead I tried one more time another PIN at the Fairphone and: it worked!
Thanks for your hint, which made my try once more!
Great!
For the sake of completeness:
Do you know what happens if you failed to many times but don’t have a google account? I don’t want to try…
I don’t know, and it scares me to try it too ^^
Ah what the heck. I’ll just try. Worst case I’ll do a hard reset.
PS: Ok after 5 tries you simply don’t get to try again for 30 second. Nothing else happens. Unfortunately I don’t see any way to unlock your phone if you can’t remember your pin even with a million tries.
This topic was automatically closed 2 days after the last reply. New replies are no longer allowed.
