Hi, I wanna install xposed. But to do it, I must flash a zip. But when I boot on recovery mod, I flash the file, and it’s writing : “e:signature verification failed” “installation aborted”. I searched how to ix it; but to do it we need cwm or twrp. I tried to install both, with many different methods, but no one works. So I can’t use xposed and its modules. Could you please help me?
Thanks a lot
I’d recommend using another recovery.
You will find more info and discussion about this issue here
https://forum.fairphone.com/t/flashing-xposed-framework-to-the-fp2-with-and-without-custom-recovery/12642?source_topic_id=17102
i’m gonna read it; thanks!
Which methods did you try? As far as I know, there is no CWM image for the FP2. A TWRP image and a manual how to install it can be found here. Scroll down to “Versions” and “Installation guide for the compiled recovery.img” though! Moreover, you’ll find a guide how to install XPosed there as well.
thanks a lot ! but it seem complicated an that’s not in french^^ but that’s enough
