i have installed \e\ OS on my fairphone 3 using my Raspberry Pi. Now i want to go back to the stock rom. I have downloaded FP3-REL-Q-3.A.0054-20200929.092252-user-fastbootimage.7z. The manual says i have to use the FP3_flashall-file to install Fairphone OS. Unfortunately this file is a binary file for x86 CPUs (why did they do that? Absolutely unnecessary). I tried to flash the image files in the \e\OS style but get stuck at system.img:
# fastboot flash boot_a boot.img
target reported max download size of 534773760 bytes
sending 'boot_a' (65536 KB)...
OKAY [  2.247s]
writing 'boot_a'...
OKAY [  0.637s]
finished. total time: 2.883s
# fastboot flash vendor_a vendor.img
sending sparse 'vendor_a' 1/2 (516652 KB)...
OKAY [ 17.593s]
writing 'vendor_a' 1/2...
OKAY [  4.946s]
sending sparse 'vendor_a' 2/2 (102968 KB)...
OKAY [  3.514s]
writing 'vendor_a' 2/2...
OKAY [  0.993s]
finished. total time: 27.046s
# fastboot flash dtbo_a dtbo.img
sending 'dtbo_a' (8192 KB)...
OKAY [  0.311s]
writing 'dtbo_a'...
OKAY [  0.101s]
finished. total time: 0.412s
# fastboot flash vbmeta_a vbmeta.img
sending 'vbmeta_a' (8 KB)...
OKAY [  0.040s]
writing 'vbmeta_a'...
OKAY [  0.021s]
finished. total time: 0.061s
# fastboot flash system_a system.img
error: cannot load 'system.img': Value too large for defined data type
I think i have to add the -S option like in the \e\OS manual. But i can’t find the right value and get the same error message every time. Can anyone help?
