Fix small sound?
my phone has very small speakers,
I do not know if my device is good. Its speaker is broken, is there any way to fix it?
Which phone do you have?
On many Android phones and the FP3, which I have, you can check the speakers via the phone dial pad.
Enter *#*#66#*#* to show testing menu with three sub-menus
Select > Service tests > Test Single > Speaker
There is also the small earpiece speaker for common phone calls, the above relates to the hands free speaker. To do the earpiece speaker the option is
Service tests > Test Single > Receiver Test
