First impressions Fairphone 2
Well, I think the phone itself decides how much power it pulls from the charger. So basically you cannot use a too powerful charger.
@anon9505190 and everybody else who posts their first impressions here including lots of problems:
Since this thread is A) in the community category and B) very active, it’s not the right place to help you with problems you are having. So please first search the forum for topics about your problems that already exist and for new issues create new threads in the FP2 help category.
Thanks.
Dear Paul,
Because of first impressions, that I wanted to post, I dont mind you not helping me here, OK ?
never mind
Sorry
Ok… I just got my second FP2 to replace my first FP2 that had lots of reboot and battery problems… (that was fast! thanks support).
Same package, same everything… only the white box isn’t broken this time…
I launched my second FP2 … and it’s been stuck at launching for half an hour now!!!
I had time to launch the old one, wipe data/factory reset, turn on again… still stuck…
This is not going very well… let me try again… battery out and… we’re in!!!
Good luck!!
I had also problems with FP2, because the display doesn’t shows anything anymore.
But after disassembling it and reassemble it, it works fine now again.
I’m very happy with the FP2, it’s fast enough (better than FP1) and has all (hardware-) features which I wanted.
If there will be an official manual to root the phone and still no update, I will see how to fix some software bugs (SIM-Card colours, different ringtones for each SIM, etc.).
I think the phone is really well done work, many thanks to the Fairphone team!!
One week with my new FP2:
  • the backup works fine with helium. Thanks to the forum
  • after deactivating the “privacy” thing, all apps are working
  • the gps signal is very fast (far better than on FP1U)
  • the phone signal is far better than FP1U. I ever get LTE or 4G speed sometimes and I got a good signal in the mountains, even with data soverage
  • Net Guard does the trick with blocking data with selected apps.
  • a few times I observed the screen flickering, but not really annoying
  • the phone is objectively heavier than FPU1, but subjectively it is not
Overall I am really happy with the new phone.
I am not sure about the battery. I just got max 1 day and a half. But I think, that’s because, it’s new and I am playing around a lot.
I definitely need root (or another way) to block the annoying ads. I didn’t know, there are so many ads, because FP1U was rooted and I installed adaway as one of the first apps.
Some minor bugs in the operating system. I am waiting for the next update.
Fairphone team: Good work so far.
For rooting have a look at the How to root with superuser thread or the one on compiling FP OSOS + root.
I’m also basically very happy with my 4-day-old FP2.
  • Flickering is occasionally noticeble but is a very minor annoyance (worst when trying to uninstall an app from homepage)
  • Compass doesn’t seem to work for 2-D map - only for the 3-D version, or is that normal?
  • Battery life is not great. Watch a couple of video clips, send an e-mail or 2 and after 20-30 minutes it’s down from 100% to 81%.
  • The extent to which Google is present is disturbing. Google is a nasty company and it’s sad that Fairphone chose to embrace that road, but I guess they have their reasons …
    But these gripes aside, the FP2 is a beautiful piece of design and a pleasure to use … Well done everybody!
One more little grumble… my FP2 never charges to 100%. It gets to 97 or 98 and then a messages on the screen says something like 'Will be fully charged in 3 minutes", but the message never goes away and the phone never reaches 100% charge.
Maybe you can have a closer look to some comments about this topic:
Have you searched the forum for this? There are quite some threads about the battery. In particular, this could be caused by this Wifi issue
[quote=“joekafka, post:153, topic:11491”]
[/quote].
Do you want to get rid of all Google stuff? In that case, the FP team announced the release of an open-source version of the FPOS without any Google apps or services and it is rumored to be released in the first quarter of 2016. You could also consider compiling this yourself from source code, if you feel confident enough.
@joekafka, alternatively you could follow this thread:
Just to put some numbers in: my FP2 needs 36 seconds to boot to the PIN input dialogue, and 46s inclusive PIN until I can use it. Is it that bad?
no, it is not bad. I wrote another statement afterwards, maybe you want to read that first.
Nevertheless, it boots slower than S5 and I wrote that I compare it to the S5. If you don’t compare then it will be difficult to talk about “fast” and “slow”, as those are purely subjective categories.
Cheers,
Georg
I’d like to conclude today by giving my comment on 2nd impression after my very first impression:
    • battery seems to last at least for 1 day while using it actively. Corrected Wifi exclamation issue!
      Remark: correction on 1st impression: 1 charge a day is enough
    • display issues: blocking without cause (sudden screenlock) vanished after 1st disassembly of FP2
      Remark: 2nd impression is how this severe problem got solved, because no locking happened last week. Looking back it became a hardware issue if display hardware modul is not assembled correctly. Subsequently I should monitor FP2-display disassembling and reassembling for quite longer time. Maybe still a risk ?
Final Result: First impression became to me leveled or relativised. The upshot (conclusion) remains that even a minor issue like a module slip and cargo shift after product compound may lead to a major issue for both the customer and the producer. It spoils not only first impression. Finally the biggest issue left is the weak battery. A trusted hardware coming from 2014 claiming higher sustainability deserves and includes longer battery longvity. Also the probable danger of glass and display scrapes for FP2 is the same as with every mobile phone.
regards
Unfortunately, the Fairphone 2 I received leaves me much less impressed than I had hoped for.
Among the positive aspects are definitely the display quality, the sturdy overall appearance and the fast and (almost) flawless usage experience. The touchscreen- and display-flickering bugs were noticeable but not grave. I assume they will soon be fixed.
Now what definitely did not impress me:
The form factor is a matter of taste but it’s not for me. It is definitely a two-handed brick of a phone without even basic one-hand usability. After hands-on I don’t like the rubber-case design decision much at all.
The camera quality in moderate cloudy conditions (like: half the year) is very slightly better than on the FP1 but still not convincing. Indoors it is so grainy as to be useless and decidedly worse than FP1 (I did side-by-side comparisons). Even outdoors it won’t replace the most basic compact camera.
The sound quality is good in depths and mid-range, but the higher range and voices sounded flat and unappealing. It doesn’t do as a music player for me. Neither does it particularly well as a sound recorder.
Taking off the screen didn’t work for me, following the instructions. No amount of pushing would make it move. Thus I can’t judge on the modularity concept.
Rooting is by now possible, but much easier e.g. on Samsung phones. Without I can’t even write to a USB Stick (an Android issue, I know).
Conclusion: I am ready to accept quite an amount of tradeoff in support of the goals of Fairphone and love the fairness, openness and repairability approach. Even for just supporting Fairphone on the way I would accept a lot of woe. I am willing to pay the 40%/60% premium compared to e.g. a S. Galaxy S5 or S4 (both can run CyanogenMod btw). If, let’s say, the core functions of the Galaxy could be graded “A” and the Farphone scores “B”, as with the display, just fine. But camera and sound score “C” at most. A more careful selection of sound and camera chip probably wouldn’t have raised the price by more than 25€. If one device replaces three or more standalone devices (phone, music player, photo, dictaphone) this is quite a sustainability factor and might outweigh the Fairphone’s current sustainability benefits.
I am very sorry, and it really pains me, but I will make use of the return policy rather than becoming an unhappy supporter. I will stay with my FP1 (that I planned to pass on) and make it last as long as at all possible.
All this is not saying that many people might be just happy with this device. It is my personal usage profile that doesn’t align with this phone.
Hi everybody,
having recieved my FP2, I promissed on the board to give my first impressions… I am sorry to say I am not completely statisfied… let me bullit-point them:
  1. recieved my trackingcode two days after my phone :slight_smile: While this does not say anything about the phone itself, it does about the organisation, I feel. It seems a bit… sloppy…
  2. The backcover is very slippery. It is plastic, but not rubbery. For me, it could be more sticky.
  3. So far, in 3 days time, it has crashed 4 times. Just rebooted itself, while I was using it. This in completely unexeptable. In one occasion, I had to remove the back and pull out the battery - no button would respond.
  4. The proximity-sensor does not always work; sometimes, the display stays on and will respond to my ear, thus switching to handsfree etc.
  5. The audiojack is not properly grounded. When I charge the phone in my car, and listen to music using the audiojack, I get a /lot/ of feedback (ie: “electrical sounds”) - so much that is actually not usable.
  6. The handsfree function (ie: putting the phone in front of you on the table, and using it with loudspeaker/mic gives a bad quality audio. The sound is too soft, and the switching between talking and listening is not properly executed.
  7. Battery life is not great. I expected, this being a bulky phone, to have at least two days. I can manage one, but only barely…
  8. The placement of the on/of switch direclty opposit the volumeswitches is impractical. It is virtually impossible to change the audiolevel without activating the on/of switch.
  9. Performance is good, but not great. Some lag in the interface can be experienced, using very basic functions. (IE: just the phone app)
  10. The camera-shutter button is nice. But you must actually hold the button while shooting video. This is very impractical and very tiresome. Confusingly, the camera makes a sound when you press it (it focusses, I guess) but it will only record when you hold the button.
  11. The flickering screen has been discussed before, but it seems this will be remedied by a software update…
I come from a Moto G, which is a cheapo-phone. I love the idea of the Fairphone, so I bought two. (One for my wife, and one for me.) But I must say that the experience is actually worse than the Moto G - a 3 year old phone. At this point in time, I’m sorry to say, I would not recommend this phone to anyone. It is a /very/ expensive phone for a mediocre experience - at best :frowning:
I am going to use it of course for the next few days. But at the moment, I feel like returning it :frowning:
I installed Nova Launcher on it; I will de-install this and see if the crashes will stop. But if they do not… I bought a very expensive phone. I don’t mind paying extra for the social part of it. In fact, I want to. But I did not expect a sub-par experience with the phone itself.
Sorry, but I am disappointed.
Paul
This is a known bug that some people experience and will hopefully be fixed soon with an update.
Proximity issues can be found on the bugs list too.
…you’ll have to use a very good USB data cable. Otherwise the fluctuation of current will cause static which results in audio crackles and ghost touches.
I heard that it gets better after a few charging cycles. There are also a lot of topics about battery tips e.g. the battery guide.
