First 3d printed transparent Slim Cover
In that case I will also go for the official one when the battery is available again. But I really want to thank you for your kind offer!!
The cover looks really sick man!
@oli.sax It looks excellent. Shame to hear the material isn’t so resistant to falls, maybe some other materials would be worth trying?
How did you print the buttons?
I think he just used the black rim (including the buttons) from an existing slim case. But if you want, you can even carefully remove the buttons (including the transparent rubber strips they are connected with) from the black rim and attach them to a new rim.
As urs said, I printed only the back of the “slim cover”, and kept the button from my existing one.
But in the 3D drawings that are provided by fairphone, there is also the buttons so they could be printed!
Hi Oli! Good suggestion to try the other model. Unfortunately the other 3d drawing is a single component. Do you know of a way to separate the shape into separate components in say Autodesk Fusion 360?
