Currently I use LinageOS with Gapps pico - only GServices with PlayStore is installed. (on a old Samsung Phone)
What have Fairphone OS  included? - Can I uninstall maps, mail and the other not wanted google stuff or do I have to install e OS?
Does Fairphone ships any apps or it is android stock?
              Hi and welcome to the forum
Fairphone install a) an app to contact them and b) a camera app specific to the FP4 (48Mpx and Wide angle) Both removable, but suggest you keep the camera for the reasons in brackets.
Otherwise FOS is a minimal Android 11 and you can de-google and remove maps etc. and you do not require a google account to set up the phone.
Here’s my efforts
    As well as those mentioned in the previous post I have uninstalled the following:-
com.google.android.gm   :: Gmail
com.google.android.googlequicksearchbox
com.google.android.apps.maps
com.google.android.calendar
com.google.android.apps.photos
com.google.android.feedback
com.google.android.gms.location.history
com.google.android.apps.docs :: Google Drive
com.google.android.videos :: Movies and TV
com.android.chrome
android.autoinstalls.config.vodafone.fairphone3
com.fairphone.myfairp…
              sounds great.  Thanks for the guide I will use that
I want to use the FairPhone OS with the camera app because Lineageos and e has always problems with camera performance.
              Dont want to minimize the helpfulness of the rasp Pi guide but we have actually a guide for FP4 to debloat
    All posters of this thread are invited to update or specify the information or add anything new.
This is a #wiki  so everyone can edit to add experiences.
For metadiscussion please see this thread
Introduction
What is debloating? When you unbox your new phone, it comes with Android that is pre-installed by the manufacturer. This is called “stock firmware”. Stock firmware also comes with a number of apps pre-installed, like native camera, browser, Google apps, etc… Some applications are manu…
    This is a collection of guides for customising Fairphone OS on FP4.
You can link to it with the unique tag #fp4guides .
It is a #wiki  post, you can edit it by clicking the green pencil icon in the bottom left corner go improve or modifiy it.
Check out the Fairphone Forum Dictionary (#dictionary ) for explanations of certain words.
Bootloader
Unlock bootloader Unlocking the bootloader will erase all your data.
Follow the instructions here: <a href="https://support.fairphone.com/hc/en-…
                system
                    July 6, 2022,  4:26pm
                  5
