Fairphone Moment broken
Hi, it has been 3 months since the last time I could’ve used Moment features.
Since two updates, it started by crash loops, fortunately the rest of the phone was ok.
And since the last update, it kinda came back but as a black screen.
Things I tried :
  • Restart phone after every following steps (even tried to shut it for one hour)
  • Empty cache and data from Moment app
  • Force stop Moment app
  • Change the input action to something else
And I’m still stuck with this black screen when the switch is enabled. This is disappointing to have a wrecked software after only 8 months of handling.
Maybe you try with dic:safemode just to be sure the problem is not caused by an installed app.
Hey Volker, thanks for this tip, learned something !
Sadly the Switch get me to the same black app
I am stuck in the same situation; Moments is botched for me. I believe the initial issue was that the “switch button settings” was messed up as I always got the message “switch button app stopped working” when flipping the button. However at that point the Moments app was set as default Home Screen and worked well. I cleared the cache/data for both the “switch button app” and and “Fairphone Moments”. This fixed the button, however it also causes “Moments” to only show the completely black screen. Seems that Moments does not populate its own data after a “Storage Reset”.
I tried contacting the support but it isn’t helpful, they even told me to download the last version of Fairphone Moment on Google Play.. It’s not available to public.. e-e
And next to that answer they suggested me to just wipe the phone. I refused since it’s been less than a year of using it. That’s not how it’s supposed to work.
Asked for the apk to update but I don’t even know if the case really gone to the right service.. Still waiting.
I am sure you have tried this but: Go to Settings > Apps > locate the fairphone moments app > select force stop > clear user data and cache > RESTART the phone, switch to fairphone moments with the button once the phone has completely restarted > set it up again. Your fairphone moments version should be 0.1.11, I think that was pushed with the latest OS update that includes the July security update.
Hi ! Yeah this is one of the first thing I’ve done when it started breaking. Tried again for chance after reading you, it doesn’t work. Still with black app when Switch is on. :frowning:
:slightly_frowning_face: that’s unfortunate because that really sounds like something for has to fix.
Same here. I did that procedure because the “Switch Settings App” broke (switch did not work anymore, the settings menu for the switch could not be opened) and someone recommended to purge the cache/data for both apps. I am quite certain that the Moments issue starten after that. I tried to reach out to support as well but man that was depressing…
​Hi everyone,
​I ran into an issue while trying to modify the settings of one of my Fairphone Moments to remove a few apps from the “allowed” list. When tapping to select which apps to show, the settings screen crashed and kicked me back to the home screen.
​Here is what I have tried so far:
  • ​Deleted one Moment to rebuild it from scratch.
  • ​Cleared cache and data for the app.
  • ​Toggled the launcher setting (switching between Fairphone Moments and Quickstep). This initially caused a black screen instead of my home screen icons and widgets, but I managed to revert it.
​Current Issue:
In the switch settings, all options work fine (e.g., Do Not Disturb, Battery Saver), except for Fairphone Moments. When I toggle it on and swipe down, I get a black screen instead of the “Moment” interface.
​Is there a way to properly reset these settings, or manually configure Moments outside the app (for example, by editing a config file)?
​Thanks for your help!
Hi, I’m having the same issue, I’ve created a post month ago. The support run out of recommandations.. So I had to film this behavior so the support can send it to the tech team. Still waiting.
Thanks.
Do you know anything I can do to help the support team troubleshoot? Like sending any info or log?
The app is up to date? Else you have to open a ticket to provide logs
The app can’t be updated, I don’t know why the support told me to update it with Google Play, as it’s private intellectual property, it’s not available to users.
After cleaning cache and data you discover that the app is totally unable to retrieves its libraries, it stays stuck with any working data.
Tho, you both talking about logs, where can I find them ?
The moments App can be updated I just did this a few days ago?
Weird, I’m in France and it’s not available in the Google Play Store. Am I missing something ?
In France also
only two available Fairphone apps on Play : gallery and fairbuds (even when connecting on a computer, not logged, so not linked to the fairphone model identification)
Maybe its up to date and will not show up as App in the store and only in updates when there is one available. I doubt its related to country. Did you test in safe mode? dic:safemode maybe any third party app is interfering?
No, I’m in the search results, not my installed apps.
Yeah that’s the first recommendation I got here. While recording for tech team, I did all my test with this mode, it doesn’t changes anything sadly..
Thats not what I meant. The app is not searchable in the playstore because its not installable on other phones, however when there are updates you can update it. So which version do you have?
Overall I guess there is not real solution other than trying a factory reset or in worst case new install of the system
