Good morning! I use a Fairphone 2 and have just moved to a new place. However, my fairphone disconnects from the new WiFi probably every 10 seconds, and then I have to manually press the WiFi button each time again to get a WiFi connection - having a connection for only about 10 seconds each, however, makes it a bit difficult, to use the WiFi on my phone at all. I think it must be a problem with the phone as I have no problems with the WiFi on my laptop and other electronic devices. Do you have any advice how I can proceed in this case to make the WiFi connection work on my fairphone? Thanks in advance!
Welcome to the community!
This issue has been raised before.
This is one of the messages that came up in a quick search:
EDIT PS
My FP2 doesn’t connect to the Fritz!Box router at all, but as there is a wireless router in the house it never really bothered me, not enough to try and configure the router in any case.
Thank you so much! And apologies for not having found that previous message myself for some reason…
No problem, just hope you get your WiFi working somehow!
