Fairphone Gen 6 doesn't ring when im getting a call
I am writing to report an issue I’ve been experiencing with the sound and vibration functions on my phone. Specifically, I am not receiving any sound or vibration notifications for calls, messages (WhatsApp, Instagram), or any other app. Even when the phone is set to vibrate mode, it does not vibrate at all. However, alarms and other system sounds work perfectly fine.
I have already checked the settings, and everything appears to be configured correctly. I’ve ensured that the volume is up, the silent mode is off, and there are no apps or settings blocking notifications. Despite this, the issue persists.
Hi, welcome to the community. Can you please check if “Do not disturb” mode is not on?
You can check this in Settings > Modes, where no mode should be set to “on”. There would also be a stop sign like icon in the status bar, beside the vibration icon, when a do not disturb mode is active.
Another thing worth checking is Settings > Sound and vibration > Vibration and haptics. Make sure that the setting is on and try adjusting the levels to see if it helps.
It is not on and I’ve checked the vibration and haptics
Can you choose another ringtone?
Yes, but it’s doesn’t change
Hello
As you can see from our responses, the issue is puzzling.
Have you transferred any settings from the other device? Does using Bluetooth change anything? What other system sounds are audible?
If you will, could you please share some of your settings? What icon appears when you press the volume buttons?
Edited to add that this is the preview from FP5 on Android 15 so it does look a bit different.
I don’t think I’ve transferred any settings from my last phone (Samsung A51), using Bluetooth doesn’t change a thing and I can hear everything expect from the calls.
I’m on vibrating mode but it just doesn’t work, its like im on silent mode, i don’t get any notifications. But even I put the sound on, I don’t hear the calls
I wonder what the icon stands for, the one between the alarm and 5G
I believe it is the one signalling the vibration mode. Just checked on my FP5 that if I switch to the vibrations, it appears on my status bar.
@Noodles Could you please try testinf through the internal testing menu, to make sure this is not a hardware fault?
  1. Go to your phone’s dialer
  2. Call *#*#2886#*#* - this will open a “secret” menu
  3. Press “MANU” - it’s very buggy for me, you might have to try a couple of times or try the other MANU button
  4. Find “Vibrator” in the list
Then let us know if the vibration motor was working when you activated it through that testing menu.
I tried all the options and none of them worked, but I remember one time when I restarted my phone it did vibrate a bit, otherwise I don’t remember seeing it vibrate
I just restarted it again and it does make a small vibration but nothing crazy and the testing menu still isn’t a success
So the icon means that the ringtone is off?
The Icon means that calls are only vibrating.
@Noodles I understood that also sound for calls is not working?
Can you share a screenshot of your settings under sound
In that case, it sounds like a hardware fault to me. I would recommend contacting Fairphone and making a warranty claim for a broken vibration motor.
If you end up sending the phone in for repairs, make sure to make a backup of your data, since the phone will be wiped after repair. You can also make a backup and perform a battery reset to make sure the issue is still there after a reset.
The phone should make a short vibration when powering on. If it’s not there, it’s almost certainly a hardware fault.
But it does make a short vibration when powering on
Are you sure there’s isn’t any other solution because I don’t want to go back to my old phone
Sorry it’s in french, also I just found out that it’s doesn’t let me be on vibration mode if I want sound when someone calls me, is that normal?
I can only send one image at a time sorry
