Just recieved the fairphone charger because i was having issues with my charger I have laying around at home.
The charger does not really seem to fit. I have to push it quite hard before the phone says its charging. That shouldnt be so i am guessing?
And even if the phone says its charging (the battery in the top gets this lightning thingie) It keeps on the same % for a loooong time. What could be wrong?
Yes, it is the original charger. It charges other phones, so I dont think its DOA. I have to push it (with some moderate force) into the charger port of my fairphone.
Then I guess there is a problem either with the cable or the USB port of your phone. I would cross check the cable with a different phone and the FP3 with a different cable.
Have you had a look inside of the USB port? If the phone isn’t new, it can collect dust and lint in there. If this is the case, then I’d try to clean it out carefully with alcohol, and some narrow soft tool. I personally find that a toothpick and some cotton can help.
Saying it fits better sounds like you may still have debris. The phone uses the Quallcom Quick charge if you have a suitable cable. The cable may work in another phone that doesn’t need the QQC3 but then not in the Fairphone. So it still could be debris in either or both the USBC cable and the phone port.
Be careful as you clean either, the contacts are a little fragile to poking with a needle.
