Fairphone 6 (OS Murena) not pairing with Boom 3 Speaker via Bluetooth
When trying to pair my Fairphone 6 with my Boom 3 speaker it says that my speaker has rejected the pairing. Has anyone experienced this? If so, how did you resolve it?
I prefer cables over Bluetooth as better for health, so I don’t have any other Bluetooth devices to try (I have the adapter and wired headphones), but I unfortunately need a speaker for work so any tips would be great!
Thanks!
So you did initiate the pairing on the speaker?
Did you try normal pairing and NFC pairing as mentioned in the manual?
I went into settings and picked up the speaker. The message on my phone then said that Boom 3 had rejected pairing. I’ve tried numerous times and it says the same thing.
Ok I understand you did not start pairing on the speaker thats mandatory in my eyes. The BT speaker need to be put in pairing mode, else pairing cant happen.
Wow! How amazing are you?!! I didn’t have the manual, so I really appreciate the link! It works :partying_face:
I thought it was. Sorted now, thanks for your advice!
