indeed; it works; thanks a lot for the hint Volker!
I should add, that I lost the Threema history, when I changed OS from Apple to eos; spring cleaning
Yes, unfortunately it’s AFAIK not directly possible to transfer chats from iOS to Android.
I you want to avoid the “spring cleaning” you might give GitHub - marvinweber/threema-ios-2-android: Tool for a Threema Migration from iOS to Android. a try.
I use Galaxy buds2 pro, and I had no audio through the earbuds until I turned off the “LE Audio” option under the specific device’s bluetooth settings. See if this helps.
I seem to have the exact same problem: Phonak hearing aids paired (bluetooth) to FP6/EOS. No notification sounds from apps like phone, clock and probably others.
Also when in the “Sound and vibration” menu there is no sound in the hearing aids when tapping the various volume settings, the “Phone ringtone” and the “Default alarm sound” settings but sound goes through with the “Default notification sound” setting.
Weird isn’t it?
FYI
I gave up and went to try Volla Quintus; it worked with some other limitations e.g. in Banking. I tried Punkt MC03 last two weeks mid July 20’26 in search of excellence (Apsy enables with Proton Mail, VPN, Drive, Wallet Threema in it’s comptactment parellel to Google Play environment,) but I found it had too many bugs for my taste, so I surrendered altogether mow and went back to iOS/ iPhone; getting too old for freedom fighting, I just realized. When I retire, I will settle for Punkt MP02 dumbphone already in during holidays
Download AI hub or gptAssist from Fdroid
