Fairphone 6 double tap to wake doesn't work reliably
When will this be fixed? Still broken to this day and works fine if i disable AoD.
Screenrecord of it not working, waiting a bit does not solve it
https://imgur.com/a/6lvZXVb
After disabling AoD it works instantly, re-enabling it means it is broken again!
https://imgur.com/a/bUAaca4
What if you wait 3 to 5 seconds after locking the screen? For me it works fine then. It still s#cks, but it’s consistent.
No matter how much i wait it does not work, only if i disable Aod
In your screencast you don’t wait a few seconds. What you do there is what I can reproduce as well.
If waiting does not matter why would i make a minutes long video? I tested it without recording and waiting, it does not work.
It won’t be minutes long, just 3-5 seconds longer :wink: I also hope this bug will be fixed. But I rarely use double tap and when I do it’s not right away after locking the screen. Can other people also do some tests? Then we can pinpoint the problem and help Fairphone to solve this faster.
Fairphone already confirmed this by the way. Hopefully they will improve it. Since other phones have no issues with this (Pixel 10 Pro for example).
I have my FP6 for a couple of days now and I have the issue as well. I turned on the Touch Sensitivity in the Settings and it seemed to work better.
