Fairphone 4 Softbrick
Hey together,
I softbricked my FP4 as followed:
Updated to latest “Fairphone OS” version
→ installed latest “Lineage OS” version
→ installed “Factory Rom Android 11” / latest “Ubuntu Touch OS” version
→ switched back to “Factory Rom Android 11”
→ used “fastboot flashing lock_critical”
→ updating to “Android 12” resulted in a softbrick
→ tried to manually flash the image files which are contained in the “ Fairphone Factory Rom 12” but frp and devinfo partition are critical locked
→ now I am stuck in a boot loop
What is the device state?
-access to bootloader
-access to fastboot
-access to recovery
-device state is unlocked
addtional info:
android recovery
Fairphone/FP4eea/FP4
12/SKQ1.220201.001/SP2K
fastboot oem device-info:
(bootloader) Verity mode: true
(bootloader) Device unlocked: true
(bootloader) Device critical unlocked: false
(bootloader) Charger screen enabled: false
Can anyone help me to help myself?
Thank you for your attention!
Best Regards
Welcome to the community :waving_hand:
First things first, after the failed A12 update, did you let the phone bootloop a few times? :thinking:
If it’s unbootable it should have switched back to the other slot after a couple of failed booting attempts.
If you can still access recovery, you might be able to sideload an ota update (which Fairphone still doesn’t provide directly :unamused_face: ). If you’re on the latest A12, the next one’s probably this:
If the ota install works but it’s still unbootable, there are a few more updates you can try after that. You won’t be able to go up to the current release though, since nobody stepped up to post the newer ota links.
Another option to try would be a factory reset, but if your phone isn’t working at this point I’m gonna go ahead and recommend contactsupport.
There have been a few similar issues with previous Ubuntu Touch installations, I don’t remember the details, you’d have to search the forum for that.
For future reference, don’t ever lock anything when you’re going from an up-to-date system to a previous version. Locking the critical partitions doesn’t trigger rollback protection iirc, but there’s also absolutely no reason to lock the critical partitions at all.
If the bootloader is locked others don’t have access to them anyway, if you don’t intend to lock the bootloader then all you’re creating is a brick risk when you lock them.
And you cant unlock critical again? Otherwise Iode didnt require critical to be unlocked, so if this is still the case to flash it might help?
Good evening,
before I manually flashed the image
files the phone has already been stuck
in a boot loop, for a split of a second
the boot logo appeared, now it still
bootloops but the boot logo is vanished.
Executing a factory reset did not solve
the problem, your other advices I will
mention later.
Thank you for your attention.
“fastboot flashing unlock_critical” resulted in an error:
FAILED (remote: 'Flashing Unlock is not allowed
x x x
Great hint, thank you!
I will try to install “Iode” tomorrow.
@anon73661646: somehow my phone reverted to a version of android 11, so the OTA update failed [cause it was supposed to update android 12..]
@yvmuell : the fastboot installation of “Iode” was successful.
Thank you both of you
, have a nice day.
Best Wishes
