My fairphone4 NFC part suddenly not working and I have done self check also fail.
Which module can I buy to replace ?
Please advise and thanks
(remark: I lost the invoice from reseller)
Best is you contact the reseller, warranty cases go through them and they should have a copy.
Else
Welcome to the community
The NFC antenna is part of the back cover, have you checked if your cover is fully snapped on.
If you have some cleaning alcohol, turn the phone off and clean the copper contacts on the cover inside / the pins that connect to the back cover.
Edit: Too slow
I clean with alcohol on two gold contact pin inside and it works again.
Thanks a lot
Sunny.
he/they/* via Fairphone Community Forum <forum@fairphone.com> 於 2025年4月29日週二 下午10:10寫道:
