I have the flip case. Had it for a few months now. The texture of it has become horrible to me. It’s one of those sensations like scratching a plate with a fork, or a chalkboard with fingernails. I can’t quite explain it, but it’s essentially very dry I think. Any way to moisturize it? It’s fake leather right? What works on that material?
I mean the texture of the rough inside, not the outside.
Is the material called micro suede?
Hello. The one with the 2. That is microsuede right? I used a toothbrush with some warm water (after it already felt bad) to scrub it, not sure if it has a lasting improving effect.
Did you see my reply? Given that you asked but stopped responding afterwards.
Hello
Sorry for confusion.
I asked for you to clarify hoping it will bring some ideas forward.
I might have some if it was a different part but as I don’t have this case, I decided not to experiment.
In brief, I would not miss any replies to my comments but will not comment unless I can contribute in at least slightly meaningful way:)
