Fairphone 4 charging slowly
I have a Fairphone 4 that charges extremely slowly, even after replacing the USB-C port.
I tested the charging with 5 different chargers and numerous cables. The charging behavior is completely random.
Sometimes it doesn’t charge at all, sometimes it changes as long as I hold the cable, sometimes it says “slow charging, 4 hours to 100%”, sometimes “slow charging, 24 hours to 100%”, and rarely it charges quickly.
And these different behaviors can occur with the same charger/cable combination.
The usb-c charging port of my fairphone 4 is new, I ordered it on Ifixit.com and changed it myself.
My computer correctly detects my phone when it successfully charges.
I need some helps please :confused:
Never encountered a similar issue. Maybe install one of those battery starts applications that measure capacity after a couple of charges. Might lead to some ideas.
It could also point to a possible old battery that is right for replacement. But I’m that case maybe the phone would also heat up during charging.
If possible I’d meet up with another fairphone user ( or fairphone angel nearby ) and try with a battery swap to not buy something you don’t need.
Re battery: I got caught with similar issue and finally found out how to kick start the battery on a YouTube video. It worked for me but I don’t trust it now. If the battery gets very low then mine needs another kick start procedure. I’ve ordered a new battery which is taking too long to arrive.
Mine does sometimes (rarely) take a lot longer than usual to load too (slow loading, from my laptop’s USB).
I haven’t detected any noticeable pattern, except that usually it happens when the battery was emptier than usual, meaning that for some reason (network availability?) the phone currently has to work more, and thus wastes more power. (Then again this is the original 2022 battery, which is still good enough (lasts one day).)
Sometimes is seems not to load at all (it says “loading”, but the charge doesn’t increase). In those cases a reboot usually helps. Did you try to reboot it when it refuses to charge?
Hello! Thanks for your replies. After trying various things, sending the phone back to the manufacturer is what finally saved it—the charging port was broken.
They had to replace the entire motherboard; it cost me 216 euros all-inclusive, but at least it saved the phone.
Have a great day!
What exactly was broken? Could you please elaborate? Because:
Yikes! :astonished_face:
The charging part directly on the board :cry:
