Fairphone 4 battery 100%size protector box case
A perfectly fitted Fairphone spare battery protective case
that’s pocket-friendly and ready to go at all times.
It protects the battery from moisture, vibration, impact, and heat, helping prevent dampness and battery swelling.
No extra tools required — when your phone runs out of power, simply swap in the battery instantly.
A clean, pract
ical alternative that eliminates the hassle of carrying a power bank.
For which Fairphone is this battery.
It can’t be Fairphone 6, because the battery is screwed in place.
F4AC1 model battery should be the one in the Fairphone 4.
ok… where to get it?
URL Website:https://kaijen.en.taiwantrade.com/
