Does/will FP5 support virtualization? what is the status of it? Also if FP4 gets android 14 ported will it have the support of virtualization?
BTW any roadmap for android 14 on FP4?
Have you tried to enable it? I read a while ago some ADB commands are needed. Not sure if the SoC has the virtualization extensions included, if lscpu
is included you can check this.
No, qualcomm_qcm6490 has no virtualisation support.
https://www.cpu-monkey.com/de/compare_cpu-qualcomm_snapdragon_8_gen_2-vs-qualcomm_qcm6490
Please see …
